Forum Home Forum Home > Technical > Electrical
  New Posts New Posts RSS Feed - Ignition key removal
  FAQ FAQ  Forum Search   Events   Register Register  Login Login
Welcome to the all new Club Nissan forum.
addy View Drop Down
Newbie
Newbie
Post Options Post Options   Thanks (0) Thanks(0)   Quote addy Quote  Post ReplyReply Direct Link To This Post Topic: Ignition key removal
    Posted: 25 Feb 2020 at 9:47am
My ignition key has started to be very difficult to remove. Goes in fine but will not extract without lots of waggling and force. The key is gripped to the final bit of exit, indicating there is a poblem at the very entry of the slot. It has score marks and wear along its entire length and I am obviously mindful it could break. I have only tried lubrication spray,an he key is fully in the return/off position.
Advice or solution appreciated
Forum Software by Web Wiz Forums® version 11.07
Copyright ©2001-2016 Web Wiz Ltd.
This page was generated in 0.408 seconds.
